[Ma...] Posted October 18, 2025 Share Posted October 18, 2025 Hi, i am looking for solution. We would like to have a report page with 5 columns for 5 stages aka 5 measured parts, but i can not find a way to select dimension result for specific stage. Is something like that possible? I mean, there should be a way because there is a trend view. Thanks Link to comment Share on other sites More sharing options...
[Ri...] Posted October 20, 2025 Share Posted October 20, 2025 Martin, I'm not certain I understand what you are asking. Can you explain in more detail? Link to comment Share on other sites More sharing options...
[Ma...] Posted October 20, 2025 Author Share Posted October 20, 2025 Please sign in to view this username. Hi, initialy this was posted in Inspect section. We are measuring N of parts as first samples and we are using report style with dimension and tolerances on beginning of a row and then up to 5 columns for actuals. I tried using stages to obtain such report, but i can not get actual from specific stage. I know you how to get that from python but i didn't find how to place a python function into report column. Any ideas? Link to comment Share on other sites More sharing options...
[Jo...] Posted October 21, 2025 Share Posted October 21, 2025 Hello Martin, "edit report" --> down left you can add columns or rows and you can also activate column or row per part/stage. I would advice against it. Features like "ok nok" "position in tolerance zone" etc. do only work for one selected part if you use columns. So if you export it you have to recreate those features by hand. Better show every part in another row (for every dimension), that way exporting into excel for example is way easier. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 21, 2025 Author Share Posted October 21, 2025 Please sign in to view this username. Hi and thanks, but i have problems to obtain results from all stages on one page. I know how to edit report and i think i can solve most of ongoing chalenges, but first i have to obtain results to be able to have one column per stage. Similar thing what i would love to solve is combined measurement into one QDAS, but i don't need to use QDAS yet. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 22, 2025 Share Posted October 22, 2025 (edited) I am not sure i get your problem right. So you want something like the following? SN1_T1 to SN1_T5 being the 5 stages in the project. For your export demands this article might help. https://techguide.zeiss.com/en/zeiss-inspect-2025/article/how_to_export_table_data_from_different_stages_in_one_file.html Edited October 22, 2025 Link to comment Share on other sites More sharing options...
[Ma...] Posted October 22, 2025 Author Share Posted October 22, 2025 Please sign in to view this username. Yes, your posted image is what i would like to have, but i can not get results ( numbers in SN1_T1, T2, ... ) into the table. I am not sure what i am doing wrong, i still get only active result. Unfortunately, posted article didn't help. Those steps are done, but only one stage shown. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 23, 2025 Share Posted October 23, 2025 (edited) edit any template. I usually start with the VDA-template. lmb into the actual column and switch on "column per stage". The actual column should be greyed out to show this. Double click in the header -> FX -> search for stage -> and choose stage name or something. In german it is "anzeigename". Should be working now. In the cells for the values you got: "$scalar_value == INVALID or result_dimension.is_vectorial?"":format(result_dimension.measured_value, "+", show_unit=false)$". But this is done automatically. I just had to the the 3 steps above. Edited October 23, 2025 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted October 23, 2025 Author Share Posted October 23, 2025 Please sign in to view this username. Ah thanks - i just found that "column per stage" - now it's working. It wasn't obvious at editing template, but on real report page it was showing. It is automatically creating columns - i was fighting why i can not select more than one column 😄 Thanks again Link to comment Share on other sites More sharing options...
