[Ch...] Posted October 28, 2025 Share Posted October 28, 2025 I know this info has already been posted on here before. I tried finding the info using forum search and using google search with the site operator and still can't find it. Don't hate me for double posting. But here's my question: I got a new computer(old one fried) and am setting up the planner simulation again. Is there a way to get my PCF probes to use the same name as the SSC probe systems? For example, I want to build the probes in SSC, then use those probes when I create programs. Here's the important thing: I don't want to swap probes names when I transfer to live CMM. I think there's a way to do this I read on here before. Kinda like mating the PCF probe to the corresponding SSC probe It's not really a big deal, But since I'm going thru the trouble to set up my planner seat again I want to do it right. Link to comment https://qualityforum.zeiss.com/topic/24899-planner-simulation-probes-pcf-vs-ssc-files/ Share on other sites More sharing options...
[No...] Posted October 29, 2025 Share Posted October 29, 2025 So you want go the reverse way, transfer the name from the PCF to the SSC? Because the normal way (SSC to PCF) is not a problem, as a PCF takes its name with it when exported. My usual workflow is to make the SSC, import it at offline seat, create program offline, then export PCF from offline and import at live CMM. The names are always consistent. Transferring from PCF to SSC would be much more complex (a SSC is a zip archive with many files in it, where the name is stored multiple times) 1 Link to comment https://qualityforum.zeiss.com/topic/24899-planner-simulation-probes-pcf-vs-ssc-files/#findComment-141003 Share on other sites More sharing options...
[Ch...] Posted October 29, 2025 Author Share Posted October 29, 2025 Maybe it was the names I had off last time. I never really paid attention to it. But I figured I'd get everything setup right this time. Link to comment https://qualityforum.zeiss.com/topic/24899-planner-simulation-probes-pcf-vs-ssc-files/#findComment-141015 Share on other sites More sharing options...
