Planner Stylus Rotation Not Synchronized
During Plan simulation, the stylus system does not display the correct location when it rotates. A0B0 goes to the correct location.
I followed the Zeiss offline setup instruction on the portal. Does anyone know how to resolve this issue?
Is this a CAA stylus or fixed angle? If CAA, you need to qualify the MasterProbe and then do the fitting position. After that I would delete this probe and remake it.
If this is fixed angle, then this document should help: https://portal.zeiss.com/knowledge-base?id=910456. I would delete everything but the down stylus and then walk through it.
Hope that helps.
