[Lu...] Posted November 18, 2025 Share Posted November 18, 2025 Somehow I can't import files called ...Sheet_ElementData.csv, which I exported from AutoForm R11. In the version R10 this works well. Both files have a one line header and some comments in the last Info column. The message I receieve in the FEA Import window is "... file does not exist or is no supported FEA file". I have also tried shortening the file name. Why is this the case? How can I import data from AutoForm R11? Thanks, Lukas Link to comment Share on other sites More sharing options...
[Lu...] Posted November 19, 2025 Author Share Posted November 19, 2025 Changing the encoding from UTF-8-BOM to UTF-8 solved the problem. According to the support handling of different encodings is planned for the future. 2 Link to comment Share on other sites More sharing options...
