[Ib...] Posted November 18, 2025 Share Posted November 18, 2025 Is there any way to make the creation of the Fitting Planes independent between stages? When I import a new stage, sometimes GOM cannot correctly identify the plane in the Actual Element, and the alignment fails. If I edit the Fitting Plane that fails, all the other stages fail as well. Is it possible to make the stages independent? Link to comment https://qualityforum.zeiss.com/topic/25129-independent-fitting-planes-at-different-stages-at-gom/ Share on other sites More sharing options...
[Ma...] Posted November 18, 2025 Share Posted November 18, 2025 I think it fails because of search distance. I don't know about your parts and how much they can differ, but from what i know you should make local bestfit for that area and then select your plane, press TAB and select that this plane have to be calculated in this alignment. This should solve it. 1 Link to comment https://qualityforum.zeiss.com/topic/25129-independent-fitting-planes-at-different-stages-at-gom/#findComment-142161 Share on other sites More sharing options...
[DW...] Posted November 18, 2025 Share Posted November 18, 2025 Please sign in to view this username. Local Best Fit helps with this kind of problem. Link to comment https://qualityforum.zeiss.com/topic/25129-independent-fitting-planes-at-different-stages-at-gom/#findComment-142185 Share on other sites More sharing options...
