[Cl...] Posted November 20, 2025 Share Posted November 20, 2025 I had something strange happen yesterday. I need to evaluate a surface profile. The geometry involved is essentially a long 180°-cylinder segment transitioning to a very long plane. So I decided to just measure this as two separate features (cylinder and plane). When I opened a freeform surface feature to recall the points into, it was already populated with entities? Link to comment Share on other sites More sharing options...
[Ri...] Posted November 21, 2025 Share Posted November 21, 2025 Entities, like model features? I have seen this before, never thought much about, I just delete the list and create the FF. Link to comment Share on other sites More sharing options...
[Ch...] Posted November 21, 2025 Share Posted November 21, 2025 You can delete the entities and choose the correct ones if they are incorrect. I believe there are times when Calypso does auto-populate the entities correctly for FFS, although I think it's default behavior is to not select any. Link to comment Share on other sites More sharing options...
[Cl...] Posted November 21, 2025 Author Share Posted November 21, 2025 It's got something to do with the naming convention. For example, I name it FFS-36-1. A different surface illuminates. I open the FFS and pull in the 4 curves I want. Click ok and the Form (0.002") appears to be what I would expect to see and there are no cad entities (Surfaces Used) in the empty field on the left, as I would expect. However, when I click ok and re-open it. Now the form is no 0.018" and the field on the left is populated with several cad entities. If I re-name it the problem disappears. There is also a FFS-36-2, but that one has no issues at all. Link to comment Share on other sites More sharing options...
