Element keywords change from stage specific to normal
Hello All,
In a project a keyword became unwanted stage specific.
How can I change this and make this keyword behave as a none stage specific?
I tried deleting and recreating, but this was not successful. It kept stage specific. Also tried it with the python interface.
What can I do? Is there a work around?
The keyword is used in table and label templates.
Thanks in advance.
Johnny
  • 2 weeks later...
Hell Johnny,
I just tried with 2026 and a stage specific keyword could be changed by ticking the box in the dialog 'Accept changes for all stages', changing the keyword -> OK. I checked by using the arrows in the dialog and with the code from the App Development documentation
# -*- coding: utf-8 -*-
import gom
for stage in gom.app.project.stages:
	print(f"Stage: {stage.name} System='{gom.app.project.in_stage[stage.index].get('user_version')}'")
Which version are you using?
Hello Nanno,
I'm using 2025 version.
What do you want me to do with the for loop?
Firstline shows like this:
Stage: 1_GD1500IA00K0M_ System=''
Is this a new option in 2026?
Regards Johnny
Hi,
it prints the keywords for every stage, so if the checkbox is on, the keyword should be the same for all stages -> Keyword is not stage specific.
It also worked in 2025 for me:
OK was clicked like in the screenshot, the result after that is on the right for every stage.
