Mesh of objects (multiscan) cut away by polygonization
Hi all,
I was wondering if somebody could help me with the following problem:
I made a scan template in Zeiss where 10 items are placed in a fixture. Mesh quality is very good but when i polygonize the mesh data the software draws a small orange box around the CAD's and if the mesh doesn't properly fit in this box it cuts away the mesh. My question is if I can increase the box size of remove it so my mesh won't be cut away.
Kind Regards
Hi Rens,
when this dialog is open, you can use selection tools (like 'through surface', 'inside cube') to edit the selection for the polygonization. This is saved when you press OK.
The orange polygonization cubes can also be changed in size by script like in the attached addon/app.
Polygonisierungsquader vergrößern.addon
