[Pa...] Posted December 6, 2025 Share Posted December 6, 2025 I've just started working with Calypso 2024. Using the GD&T position with MMC invoked, my report now shows the size of every hole used to calculate the bonus tolerance. I'd like to remove this from the report, as the same hole sizes show up once in the PLTZF, once in the FLTZF, and once where I just called for the diameter. My part has 100 holes so eliminating these redundancies will remove 200 lines from the report. I'm just poking around now to see if I can find a setting somewhere but any help would be appreciated. Link to comment Share on other sites More sharing options...
[Ky...] Posted December 8, 2025 Share Posted December 8, 2025 I don't think the separate characteristics are necessary in the new GD&T engine. After you make sure that the size tolerance is set correctly in the characteristic (the diameter symbol next to the MMC symbol in the characteristic), you can delete or hide any additional diameter characteristics you or the system made (see https://portal.zeiss.com/knowledge-base?id=1128721 for instructions on hiding the characteristics, assuming you are in the US). Link to comment Share on other sites More sharing options...
[Pa...] Posted December 11, 2025 Author Share Posted December 11, 2025 Unfortunately this isn't a solution, Kyle, though I am in the US. I'm familiar with the process in the linked KB article, which has been necessary since they broke the ability to mask and use text fields as we were doing prior to 2022 with the rollout of PiWeb. The additional characteristics appear on the report but nowhere else in the program. They do not show in the chars list so I cannot mask, mark, rename, or anything else. In my last program they just made a 70 page document into a 116 page document. The world ended here in the eyes of my internal customers. This output is way too much for my colleagues. I'm forced to avoid using the GDT positions as long as this persists. It would be really handy if Zeiss would roll out documentation on major changes like this one beyond the release notes. So many of the selections in GDT position use language which does not appear in ISO or ASME (like the "suggested" term that appears in all evaluation dropdowns) that we're forced to guess and test to discover what it all means. I believe the entire purpose of creating, selling, and supporting this (really really expensive) software is to ease the inspection burden on industry, which is to say we all have full time jobs. Those of us capable of discerning what the obtuse language means through testing are (at least in my case) very busy with daily demands, and likely none of us has a manager that wants to hear "I got the training. I just won't know how to use it without an indeterminate number of hours testing". My take: Stick with the language in the specs. If you ain't got documentation it ain't ready yet. Rant over. 4 Link to comment Share on other sites More sharing options...
[Sh...] Posted December 16, 2025 Share Posted December 16, 2025 I am having this same issue. The problem at our company is that if it shows up that it is non conforming on our PiWeb Report for these specific diameter dimensions for MMC/MMB or LMC/LMB, it is then tagged "nonconforming". Unfortunately, no amount of training or guidelines for our company is going to help. I'm half tempted to not use the GDT Position now and I hope this has been corrected in new versions of Calypso. 1 Link to comment Share on other sites More sharing options...
[Sh...] Posted December 17, 2025 Share Posted December 17, 2025 All, I put in a ticket with Zeiss and we figured out a solution for this issue. If any of you are familiar with hiding the ".M, .L" characteristics mentioned on Knowledgebase - https://portal.zeiss.com/knowledge-base?id=458620 , the solution is an addition to that code in PiWeb. For my specific case I wanted to hide the diameters for GDT Position for MMR/LMR and to do that we used the code: {^((?!\.\(M|L\)|\^Diameter For).)*$} If there is anything else that you particularly want to hide, I suggest being very specific in that code about the characteristic name so that you don't accidentally hide something important. 1 Link to comment Share on other sites More sharing options...
[Lu...] Posted December 17, 2025 Share Posted December 17, 2025 I had the same issue and were told by Zeiss guys I can't hide what you want to hide The only solution I have is to make a "Result element" and define the characteristics with variables That's a lot of manual work with high risk of mistake but I have no better idea I haven't tried the solution above that Shawn has posted Link to comment Share on other sites More sharing options...
[Ri...] Posted December 18, 2025 Share Posted December 18, 2025 Please sign in to view this quote. I am under the impression that regardless of hiding via PiWeb, if the feature is OOT, it will still show up in the "No. values: red" at the top of the report. Link to comment Share on other sites More sharing options...
[Sh...] Posted December 18, 2025 Share Posted December 18, 2025 Please sign in to view this quote. Oh I wouldn't be surprised but at least our company is aware of that and are excepting of it. Surprised that has not been fixed yet though, huge problem. I think if we all bombard the My Voice with likes on created issues, Germany may react. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 18, 2025 Share Posted December 18, 2025 Please sign in to view this quote. They should have a toggle for users who are not using SPC through PiWeb, just turn it off. 🫤 2 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 19, 2025 Share Posted December 19, 2025 Just so you are aware, this is not this case for Calypso 2025. These diameters are no longer defaulted on the report. 🙂 1 1 Link to comment Share on other sites More sharing options...
[Sh...] Posted December 22, 2025 Share Posted December 22, 2025 Now they just need to fix the ZAS head in simulation, last I left it it destroyed the SDCO and they were elevating the issue to Germany. Link to comment Share on other sites More sharing options...
[Pa...] Posted Sunday at 12:55 PM Author Share Posted Sunday at 12:55 PM I finally got around to trying Shawn's fix. It worked exactly as suggested. PiWeb designer is obtuse and terrible. I love the statement from the cited KB article: "highlight the relevant table". Clear as mud. I figured it out. For reference, the code in Shawn's suggestion will hide the (M) line, the (L) line, and these additional diameters. Those of us already hiding (M) and (L) lines will overwrite that existing code with this. Link to comment Share on other sites More sharing options...
[CA...] Posted 23 hours ago Share Posted 23 hours ago I'm just going to add on to this tread before starting a new one. Now that I have "hidden" the extra diameter line successfully, does anyone have any input as to why my reports do not show the associated icons for GDT evals when using the gdt engine? instead of the icon for perp, parallel, cyclindricity, position, etc., it is showing a picto of a sheet of paper. Link to comment Share on other sites More sharing options...
[Ma...] Posted 23 hours ago Share Posted 23 hours ago (edited) Please sign in to view this username. I've never got this resolved - restarting Calypso is working and i can not replicate this behaviour on purpose - it's random Edited 23 hours ago Link to comment Share on other sites More sharing options...
[CA...] Posted 23 hours ago Share Posted 23 hours ago Thanks, Martin. I'll keep playing around with it to see what happens. I did also start a dedicated thread for this issue here in General Category as well, in case there are other answers there. Link to comment Share on other sites More sharing options...
