[Za...] Posted January 7 Share Posted January 7 I am wondering how to create a max distance between these two outside features that could be considered two ellipse, curves, arcs, or circles. I've made many attempts at curve distances or edge distances and slotted lengths and everything comes out slightly different or just doesn't work. Any advice on creating a max distance between two rounded features? Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/ Share on other sites More sharing options...
[Ma...] Posted January 8 Share Posted January 8 I would use caliper disc from both sides to obtain 2 points, which can be then used for 2point distance Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-144295 Share on other sites More sharing options...
[Je...] Posted January 8 Share Posted January 8 Hello Zachery, I would use touching discs to measure the outer points (creating a silhouette before is also an option). Best regards, Jens Braun Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-144297 Share on other sites More sharing options...
[Da...] Posted March 12 Share Posted March 12 I'm having difficulties with the same type of measurements. Could someone post a short video for how this is done? Or explain more detailed? Best regards, Daniel Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-147595 Share on other sites More sharing options...
[Ma...] Posted March 12 Share Posted March 12 There is a difference between caliper disc and edge. But for edge you are defining edge axis. What i do on problematic part: select caliper disc define in which direction you want to take it define as small disc radius as you can - this will define your nominal position now find and edit measured point ( green one ) adjust measured point by clicking on a model edit radius to cover more area I can not do a video of whole thing on free licence ( post edit limitation ), but i can try next week It's not that hard since you figure out what is doing what. 1 Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-147607 Share on other sites More sharing options...
[Da...] Posted March 16 Share Posted March 16 Thanks Martin, I will try this out! Have a nice day 🙂 Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-147785 Share on other sites More sharing options...
[Yi...] Posted March 18 Share Posted March 18 One more a very usefull tool is Continuous curve distance. When applying this tool, you can than activate the maximum deviation label and you will get the max distance! Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-147951 Share on other sites More sharing options...
[An...] Posted September 4 Share Posted September 4 Hi I don't create a new topic, I ask in this How to measurment a this dimension? I know about a caliper distance but is there another option? I mean a dimension 111.4. I read about Continuous curve distance to use, but I dont know what is name in my language. Can You explain on video or pic of "Continuous curve distance" and how use that? If this a wrong method tell me. Its about to measurment iregular, non symetrical form. Thanks Link to comment https://qualityforum.zeiss.com/topic/25493-how-to-create-a-max-distance/#findComment-155314 Share on other sites More sharing options...
