[Ma...] Posted Tuesday at 03:32 PM Share Posted Tuesday at 03:32 PM Hi Guys, I would like to prepare multiple measurement plans for the two small parts below. I have never measured multiple parts in a single setup before. Could you give me some guidance on where to start? It is important for me to get two separate reports after measurement and the programs cannot be identical, because, one will require an approach from -X and the other from +X Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 04:01 PM Share Posted Tuesday at 04:01 PM In autorun you can have two programs in same panel. Then with "CTRL" on keyboard you can select more programs to run - you fill parameters ( header ) and it will perform two measurements on one go. But this is not different from usual work. Unsless you would like to have both parts in one program ( same part, but different probes ) that can be done too. Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 04:44 PM Author Share Posted Tuesday at 04:44 PM Please sign in to view this username. thanks for answer. This program will be run by CNC operators from production. The machine works together with a robot that mounts a previously prepared vise onto the machine table. The operator does not even need to approach the measuring machine. From the robot interface, they scan a QR code with the drawing number (the measurement plan has the same name), and the program runs automatically. So in this case, the auto-run function probably does not make sense, right? Can I have a standard measurement program with two CAD models in it and still get two separate measurement reports? Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 05:05 PM Share Posted Tuesday at 05:05 PM I am no expert in codes for Calypso, but there are some here. What i know they are using bar code and search field to find correct program to run. If you have PCM licence, then this can be doable. For program - normally you can not have two protocols in one program using same characteristics. You can have setup autorun for having twice the same program, only in run parameters you can use miniplans, or using different strategy. Miniplans will use doubled characteristics ( you have to copy them, rename them and use different features for different probe / safety plane ) Using different strategy is using same characteristics and features, you have to only edit all feature's strategy for different probe / safety plane. Using robots and code reader is outside of my knowledge and wasn't mentioned in initial post. I would advise you to modify title to bring someone with knowledge. Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 05:20 PM Author Share Posted Tuesday at 05:20 PM Maybe I didn’t explain myself well. The machine and robot with a separate panel don’t matter here. I just wanted to explain why I need this program. The robot works with the machine, and for now, everything is fine 🙂 Until now, we only used the program for one part. Now we want to measure multiple parts in one setup. You mentioned a miniplan, which could be a good idea. My question is: can I make two seperate reports? One for the main base part (first part) and one for the miniplan (second part). I know the characteristic will have different name, but that’s okay. Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 05:31 PM Share Posted Tuesday at 05:31 PM Well, you can not run one program and get two protocols. But what is with a robot? If it can place parts, then run code, which will run a program, then why not let robot place two parts, then scan and run part1, then scan and run part2? Both would have another pallet program with defined strategy, but same program. Link to comment Share on other sites More sharing options...
[Je...] Posted Tuesday at 08:40 PM Share Posted Tuesday at 08:40 PM Please sign in to view this username. , Autorun is your best option per the workflow you mentioned, including the automation cell + barcode scanner. It's not impossible to run two parts / two CAD models in the same measurement plan and parse it to two reports, but you would be using a complicated workaround to do what Autorun already accomplishes. Link to comment Share on other sites More sharing options...
[Jo...] Posted Wednesday at 09:30 PM Share Posted Wednesday at 09:30 PM If you do have PCM you could use autorun with a pallet, then create 1 program with two strategies in the features that require different tips/approach/etc. Then, in the presetting of your program code in to use the corresponding strategy dependent on pallet location number. If you do not want to do multiple strategies, you could do this with miniplans as well. Either method would have the same outcome you're looking for. I have accomplished this in a past, but I no longer have access to the programs, or I would share the exact PCM. Link to comment Share on other sites More sharing options...
[Jo...] Posted Thursday at 01:51 PM Share Posted Thursday at 01:51 PM I believe this is what you will need. getRecordHead("palletlocationnumber") setRunID("your miniplan name") 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted Thursday at 02:55 PM Share Posted Thursday at 02:55 PM This should do. //Used to run a specific Miniplan dependent on Pallet Location Number, add additional pallet locations as needed PltNum=getRecordHead("palletlocationnumber") if PltNum=="1" then setRunID("Run Left") endif if PltNum=="2" then setRunID("Run Right") endif Link to comment Share on other sites More sharing options...
[Lu...] Posted Friday at 12:37 PM Share Posted Friday at 12:37 PM Do you need to have all in one measurement plan? This is my assumption, otherwise you wouldn't open the thread If so, a mini-plan will do the job. You would have one mini-plan for the measurement from the left and another one for the measurement from the right. I don't know how it work with bar codes and Auto-Run, I have no experience in it Or can they be separate plans? Link to comment Share on other sites More sharing options...
