Multiple measurement plans - how to start
Hi Guys,
I would like to prepare multiple measurement plans for the two small parts below.
I have never measured multiple parts in a single setup before.
Could you give me some guidance on where to start?
It is important for me to get two separate reports after measurement and the programs cannot be identical, because, one will require an approach from -X and the other from +X
In autorun you can have two programs in same panel. Then with "CTRL" on keyboard you can select more programs to run - you fill parameters ( header ) and it will perform two measurements on one go.
But this is not different from usual work.
Unsless you would like to have both parts in one program ( same part, but different probes ) that can be done too.
 thanks for answer.
This program will be run by CNC operators from production. The machine works together with a robot that mounts a previously prepared vise onto the machine table. The operator does not even need to approach the measuring machine. From the robot interface, they scan a QR code with the drawing number (the measurement plan has the same name), and the program runs automatically.
So in this case, the auto-run function probably does not make sense, right?
Can I have a standard measurement program with two CAD models in it and still get two separate measurement reports?
I am no expert in codes for Calypso, but there are some here.
What i know they are using bar code and search field to find correct program to run. If you have PCM licence, then this can be doable.
For program - normally you can not have two protocols in one program using same characteristics.
You can have setup autorun for having twice the same program, only in run parameters you can use miniplans, or using different strategy.
Miniplans will use doubled characteristics ( you have to copy them, rename them and use different features for different probe / safety plane )
Using different strategy is using same characteristics and features, you have to only edit all feature's strategy for different probe / safety plane.
Using robots and code reader is outside of my knowledge and wasn't mentioned in initial post.
I would advise you to modify title to bring someone with knowledge.
Maybe I didn’t explain myself well. The machine and robot with a separate panel don’t matter here. I just wanted to explain why I need this program. The robot works with the machine, and for now, everything is fine 🙂
Until now, we only used the program for one part. Now we want to measure multiple parts in one setup.
You mentioned a miniplan, which could be a good idea.
My question is: can I make two seperate reports? One for the main base part (first part) and one for the miniplan (second part). I know the characteristic will have different name, but that’s okay.
Well, you can not run one program and get two protocols.
But what is with a robot? If it can place parts, then run code, which will run a program, then why not let robot place two parts, then scan and run part1, then scan and run part2? Both would have another pallet program with defined strategy, but same program.
, Autorun is your best option per the workflow you mentioned, including the automation cell + barcode scanner.
It's not impossible to run two parts / two CAD models in the same measurement plan and parse it to two reports, but you would be using a complicated workaround to do what Autorun already accomplishes.
If you do have PCM you could use autorun with a pallet, then create 1 program with two strategies in the features that require different tips/approach/etc.
Then, in the presetting of your program code in to use the corresponding strategy dependent on pallet location number.
If you do not want to do multiple strategies, you could do this with miniplans as well. Either method would have the same outcome you're looking for.
I have accomplished this in a past, but I no longer have access to the programs, or I would share the exact PCM.
I believe this is what you will need.
getRecordHead("palletlocationnumber")
setRunID("your miniplan name")
This should do.
//Used to run a specific Miniplan dependent on Pallet Location Number, add additional pallet locations as needed
PltNum=getRecordHead("palletlocationnumber")
if PltNum=="1" then
	setRunID("Run Left")
endif
if PltNum=="2" then
	setRunID("Run Right")
endif
Do you need to have all in one measurement plan? This is my assumption, otherwise you wouldn't open the thread
If so, a mini-plan will do the job. You would have one mini-plan for the measurement from the left and another one for the measurement from the right. I don't know how it work with bar codes and Auto-Run, I have no experience in it
Or can they be separate plans?
Yes, we need a single measurement program with the option to export two measurement reports.
Our colleague from Zeiss is going to ask about this with his team tomorrow. If we find solution to this problem, I will share it here.
Maybe it will be useful to someone someday 🙂
You may be able to accomplish this using the "Condition" function and groups. This should be available in the "Free" PCM of Calypso.
Two characteristic sets ("Left" and "Right" ). Right click - Condition, uncheck post condition, add condition listed below. You may need two == signs, I can't remember.
I have not tested if this works. You may need to change the run order to "From Characteristic list".
image.png.cb1bb10b513d4d57b54f8d2d3526402d.pngimage.png.6f0aeab8af82e54f1fe893bd045161dd.png
If you want to run pallet program with two nests, then Josephs idea with simple condition is fine. Only problem are names of characteristics - can not be same for both sides.
I am not sure if you can select strategy via this simple nonlicense pcm option. But this can keep not doubled features and characteristics.
