[Th...] Posted February 2 Share Posted February 2 Hello everyone, I've been doing videos using X-ray for some time now. Usually we only make translation videos into the inspected volume to show our clients. This time I wanted to display the CAD file in the video to show the dynamic CAD cut overimposed on the volume during the video. But it seems the CAD file doesn't appear correctly. I attach to this help request several images to explain. Thanks in advance for any help you can provide ! Thomas JOERGER Link to comment Share on other sites More sharing options...
[Ra...] Posted 8 hours ago Share Posted 8 hours ago Hello, Thank you for the detailed screenshots. From what I can see, the CAD model is visible in the section view within the workspace, but the CAD contour is not being included when the report page is exported as a video. The exported video appears to contain only the volume section data. Looking at the images, I would lean toward this being either a limitation of the video renderer or a defect in the export process rather than a project setup issue. Link to comment Share on other sites More sharing options...
