[Sh...] Posted February 4 Share Posted February 4 (edited) I am using PCM code to report the Temperature with a Temperature Probe and I noticed that Subsequent Evaluation does not work properly or as intended for Temperature readings. I believe it is because it is similar to pulling actual data from a probe and is not related to a feature or characteristic. I've tried and failed using Result Element and also Theoretical features using this code: getActual("Temperature probing1").temperatureF Does anyone have any ideas how to store this original number of the actual so that it can be pulled into Subsequent Evaluation? Edited February 4 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted February 4 Share Posted February 4 Shawn, Great question, I ran into same issue, I think I may have assigned it a VARiable and possibly used in a theoretical feature. I may have also had to go back and grab it from the reports each time as well. THe real question is, does Calypso apply the same temp comp for a subseqent eval ? 🤔 or are points saved with the temp comp applied ? probably the latter. Link to comment Share on other sites More sharing options...
[Cr...] Posted February 4 Share Posted February 4 Please sign in to view this quote. I have seen after running a subsequent evaluation, then going into the run window to start a part, the temp comp from the actual measuring run of the subsequent evaluation is in the temp comp window. 1 Link to comment Share on other sites More sharing options...
[Sh...] Posted February 5 Author Share Posted February 5 Please sign in to view this quote. OOF 1 Link to comment Share on other sites More sharing options...
