[Ma...] Posted Thursday at 11:08 AM Share Posted Thursday at 11:08 AM Good morning to all, I have a problem with RPS Alignment. I have to make a alignment between a knob and the CAD and I have a problem to block the Y rotation movement. X and Y are OK, but in Z I have to put 2 points to zero and divide the errore to the others two points. To do this I have make a first alignment where I put 1 and 2 to zero (first imagine) and a second alignment with all points, letting all the movment free exept for the X rotation (second image). The result is as visible in the third image, where it's shown the problem: the error wasn't divided in equal part. How can I do? I watch to other alignment method, but nothing seems to be useful for me. Thank you very much! Link to comment Share on other sites More sharing options...
[Ma...] Posted Thursday at 04:10 PM Share Posted Thursday at 04:10 PM I have problems with understanding your problem. What i would do is using circles instead of your points 1 and 2. Or use your RPS montaggio as first and then correct Z value by points 1 and 2. Or if it's confidential we can go by PM Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 04:24 PM Author Share Posted Friday at 04:24 PM Thank you for you response! It's hard to explain with images.. I try with a video.. GOMSoftware_2s0jc536Ii.mp4 Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 06:09 PM Share Posted Friday at 06:09 PM Well what i would do is making those two points in holes after the big rps. Also i would check at measured elements to be evaluated in this first rps. But even after that you will get different deviation because of X rotation. Because one point on left is further from center than you second point on right side. Link to comment Share on other sites More sharing options...
