[ph...] Posted February 23 Share Posted February 23 i have installed 2026 but i cant open the software as it says no license?. my suite points to 2025 on the server and works fine. do i need to do anything to be able to use 2026 ? Link to comment Share on other sites More sharing options...
[Cl...] Posted February 23 Share Posted February 23 Have you updated your license in the License Manager on the Zeiss Portal? I would check the portal and see if the license for that machine is on the correct verison. Link to comment Share on other sites More sharing options...
[ph...] Posted February 23 Author Share Posted February 23 Please sign in to view this quote. it says i need to verify with a serial number and entitlement id . the recent license update on our server was to 2025 version. i simply then point to that server and in my application list it is available to use. we only use the software and no hardware so i dont have a serial number. Link to comment Share on other sites More sharing options...
[Na...] Posted February 24 Share Posted February 24 Hi Phil, as Please sign in to view this username. wrote, you probably just have to update the license to 2026. Information about your current license like the entitlement ID can be found in the Suite. ZEISS Quality Tech Guide Link to comment Share on other sites More sharing options...
[Mi...] Posted February 27 Share Posted February 27 Here is a video tutorial on how to update to a 2026 license through the portal. https://portal.zeiss.com/iqr-academy/video/2No-uamZaJuV99yngepcDh Also a PDF on the license manager. https://dcc-assets.zeiss.com/iqs/[Customer]_Licensemanager_2.0_Instructions_EN_v1.1.pdf Link to comment Share on other sites More sharing options...
[ph...] Posted 4 hours ago Author Share Posted 4 hours ago showing as active but i cant access through the suite. when i input the license key in the suite , it tells me floating licenses not allowed. Link to comment Share on other sites More sharing options...
[ph...] Posted 4 hours ago Author Share Posted 4 hours ago Please sign in to view this quote. Link to comment Share on other sites More sharing options...
