[Qu...] Posted Wednesday at 03:31 PM Share Posted Wednesday at 03:31 PM Hello all, How would you go about to set up the features to create the datums for this slot. I am using symmetry for datum -B- and a combination of 3d lines and intersections for datum -C-. Is there a better way to approach this, I would like to know to create a feature of size for -C- in the case I want to apply MMB. Thank you! Link to comment Share on other sites More sharing options...
[Jo...] Posted Wednesday at 03:57 PM Share Posted Wednesday at 03:57 PM (edited) Hello Quang, depending on the position of the datum-"box" to the dimension-arrow the datum has to be build differently. Meaning there is information missing from your scetch. Is the datum-box in line with the arrow, then it is a derived element like an axis, a middle line or a middle plane. If the datum-box is not like that then it means the actual element it is attached to. Edited Wednesday at 03:58 PM Link to comment Share on other sites More sharing options...
[Qu...] Posted Wednesday at 04:43 PM Author Share Posted Wednesday at 04:43 PM The datums are the full width and the length of the slot. Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 06:13 PM Share Posted Wednesday at 06:13 PM Do you need MMB on datum C? Link to comment Share on other sites More sharing options...
[Qu...] Posted Wednesday at 06:26 PM Author Share Posted Wednesday at 06:26 PM Yes, The best method I have right now is only able to create a center point between the radius and the plane. If there is a better way to represent the datum it would be great. Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 06:31 PM Share Posted Wednesday at 06:31 PM Then you could use symmetry point ( not in Construction as Symmetry construction ) - should work with recalled measured point. At least you can try it Link to comment Share on other sites More sharing options...
[Qu...] Posted Wednesday at 10:16 PM Author Share Posted Wednesday at 10:16 PM How would that work if one of the feature is a cylinder? Link to comment Share on other sites More sharing options...
[Pa...] Posted Thursday at 12:24 PM Share Posted Thursday at 12:24 PM What strange callout. Datum B is not a Feature of Size so can't be used as a datum. But if this is what the customer or the engineer thinks he wants, we can give him a result. I'd grab the sides of the slot with a symmetry plane. I'd scan the full R end of the slot for a circle. I'd scan the end of the slot or the face it breaks into, and create an intersection between the symmetry plane and the end face at the same height as the circle. I'd created a 2D line between this intersection and the circle centerpoint. Call this B. Calypso won't be able to apply any MMB etc. Link to comment Share on other sites More sharing options...
[Ze...] Posted Thursday at 02:11 PM Share Posted Thursday at 02:11 PM (edited) Datum B is a width. I width is a feature of size. For Datum C you could grab the maximum coordinate at the apex of the circular end and create a width from each side. To use MMB you might need to do the old school method of creating a circle from the end points of the slot and using that to determine MMC/MMB. Edited Thursday at 02:12 PM Link to comment Share on other sites More sharing options...
[Pa...] Posted Thursday at 04:07 PM Share Posted Thursday at 04:07 PM grr... Yeah I got my datums swapped. I described the part I'm working on, not the one you are... Link to comment Share on other sites More sharing options...
[Ze...] Posted Thursday at 04:59 PM Share Posted Thursday at 04:59 PM No offense meant, Pat. Just trying to provide information that might help. Link to comment Share on other sites More sharing options...
[Qu...] Posted 4 hours ago Author Share Posted 4 hours ago Thank you for all the feedbacks! I would share the drawing if I could but the replies helped clarify the issue a lot. Link to comment Share on other sites More sharing options...
