[Mi...] Posted February 26 Share Posted February 26 So I have a pre-installed program for our rotary table (RT) After homing the CMM I need to redo the RT axis, the Rough RT Location is a program pre-installed and uses the center bore of the RT for it's position. I have 2 circles in the features column and one is base alignment and the other is CMM alignment, they are within a few microns of each other in X and Y Would one be more ideal to use than the other for establishing the rough location before doing an RT Axis program? Link to comment Share on other sites More sharing options...
[Ch...] Posted February 26 Share Posted February 26 I don't think this will have any effect. It is only for the 'rough' location. you should be fine. 1 Link to comment Share on other sites More sharing options...
[Mi...] Posted February 26 Author Share Posted February 26 Thanks, I just looked at the RT position and axis in the RT window and it is relative to base alignment once the RT Axis program is run with the ref spheres. And the X, Y location is different than the Rough RT Location and would be more exact. Link to comment Share on other sites More sharing options...
