[Di...] Posted February 6, 2023 Share Posted February 6, 2023 Hello all, I'm struggling with this situation and I can't find the problem Every time that I change any program that I have the program doesn't overwrite the existing saved file he makes me create a new save file I saw that the software was opening the program on (read only) I change that on the properties before I open the program but when I'm going to save the alteration he ask me again to create a new save because he can not overwrite the existing one Is this some option that is active in definitions??? Link to comment https://qualityforum.zeiss.com/topic/2602-overwriting-issues/ Share on other sites More sharing options...
[Na...] Posted February 6, 2023 Share Posted February 6, 2023 Hell Diogo, is this an old project opened in a newer version? Overwriting is disabled in this case, because you can only open old projects in a newer version but not the other way round. You have to save it with the newer version and open this project with the newer version again to overwrite it. Nanno Link to comment https://qualityforum.zeiss.com/topic/2602-overwriting-issues/#findComment-6762 Share on other sites More sharing options...
[Di...] Posted February 6, 2023 Author Share Posted February 6, 2023 Hello Nanno Thank you for the help I'll check if this situation only happens with the old programs and I'll tested the new that I create to see if this occur Link to comment https://qualityforum.zeiss.com/topic/2602-overwriting-issues/#findComment-6764 Share on other sites More sharing options...
