[3b...] Posted February 9, 2023 Share Posted February 9, 2023 As software packaging guy I need the switches to do the uninstall silent without user interaction. In the documentation I cannot find anything. Link to comment https://qualityforum.zeiss.com/topic/2618-uninstall-switches-to-it-silent-unattend-gom-2022/ Share on other sites More sharing options...
[Je...] Posted February 24, 2023 Share Posted February 24, 2023 Hello Mr. Braun, I have attached a document which also covers silent installation. If that is not helping / silent unistall is not covered I will try to get more information about this topic. Best regards, Jens Braun GKB-Bestpracticeforadministrators-GOMSoftware2021-240223-0822-4.pdf Link to comment https://qualityforum.zeiss.com/topic/2618-uninstall-switches-to-it-silent-unattend-gom-2022/#findComment-7009 Share on other sites More sharing options...
[Pe...] Posted July 19, 2023 Share Posted July 19, 2023 Excuse me for bringing up this topic again, but I've got a problem with the silent unistall. If you are running the "UnInstall.exe", then you'll get a popup window asking to select a installer language. This prevents a complete silent install. Is there any solution for this issue? Kind regards, Peter Trump Link to comment https://qualityforum.zeiss.com/topic/2618-uninstall-switches-to-it-silent-unattend-gom-2022/#findComment-8285 Share on other sites More sharing options...
[Ku...] Posted September 14, 2023 Share Posted September 14, 2023 Hello, Parameter "/S" needs to be added to run uninstaller in silent mode. There could be also problem with waiting for the end for uninstallation process but: In batch another parameter “_?=C:\Program Files\GOM\2022” needs to be used as well (but then "c:\Program Files\GOM\2022\UnInstall.exe" might remain after installation) In Powershell the following command handle the case: Start-Process "c:\Program Files\GOM\2022\UnInstall.exe" -ArgumentList "/S" -Wait Comment: In the examples it is assumed that GOM 2022 is installed in “c:\Program Files\GOM\2022” Best regards, Wojciech Kurowski Link to comment https://qualityforum.zeiss.com/topic/2618-uninstall-switches-to-it-silent-unattend-gom-2022/#findComment-8778 Share on other sites More sharing options...
