ZCR 70 Holders with XTR Plates
I have 5 ZCR 70 Holders with 5 XTR Plates that I had to remove from the CMM and clean them up because they are on a CMM that is on the production floor. When I put them back on the CMM and relocated each holder now, I have an issue where the Vast XTR Gold will load all 5 but will only store 4 out of the 5. Any ideas would be very much appreciated.
Make sure the position tab is set correctly for an XTR. I can't remember which numbers apply to which, but I believe it is typically 4 and 6 that you use. The easiest way to tell would be to look at one that currently works and set it to that.
