Only part of a Scan shows up in my report??
I have 4 profile scans on my part all with the same strategy and same number of points, 3 of the scans show up fine on the report when you turn the display on, but the 4th scan only half of the entire scan shows up in the report??? Any help would be greatly appreciated.....
Are these Curves?  If so, the number of curve points in the segment might not reflect how many points are in the curve.  This can happen if you create a curve and then increase the number of points.  To be clear, I am not speaking about the number of points below the scanning speed.  In the lower half of the window.
