[Gö...] Posted March 25 Share Posted March 25 Hello, I created a User Defined Table Format, and I wanted to use this format to export results. Also, I need to export the results in different alignments. For now, I use a script that changes the alignment and exports the table related to the alignment via report pages in a new folder, and merges the CSV files into one file. I have already have the script and am using that with manually. But I need to make this process automatically using Kiosk. When the Kiosk is started and after the selection of a template for a reference Kiosk going to do photogrammetry and scan, and the polygonization, and calculates. After this, the kiosk normally closes, but before the kiosk closes itself, I needed to call the script to see the results in a CSV file. Also, with the template change required script will change as well. I can merge the scripts and select the related script according to template name, etc. It won't be a problem, but how can I interfie Kiosk before its close? I tried using the Kiosk table export formats, but I couldn't implement a user-defined table format that supports different alignments. This could also work. Link to comment https://qualityforum.zeiss.com/topic/26217-export-user-defined-table-format-after-kiosk-done/ Share on other sites More sharing options...
[Na...] Posted March 30 Share Posted March 30 Hi Gökhan, the Export CSV By Report Page will export elements in different alignments. The alignments are defined by report pages. The result file is defined by an export template and does not represent your table 1:1 probably. The export csv by report pages can be added to the exports in the kiosk and does not need an additional script. Nanno Link to comment https://qualityforum.zeiss.com/topic/26217-export-user-defined-table-format-after-kiosk-done/#findComment-148364 Share on other sites More sharing options...
