[Ba...] Posted Tuesday at 08:00 AM Share Posted Tuesday at 08:00 AM Hello experts. I am using calypso 7.4 version but I do not have a PCM license. I would like to see a warning on the screen for a characteristic that is out of tolerance. Could there be a solution to this situation other than PCM? I tried the Message option in the characteristic editor menu, but the system does not work.I searched in the forum. but I couldn't find it. I'm not sure I brought this up to the right group. I'm sorry about that. Link to comment Share on other sites More sharing options...
[Jö...] Posted Tuesday at 10:36 AM Share Posted Tuesday at 10:36 AM Hallo Erim, gehe zu Prüfplan Editor dann auf Protokolle und dann auf Warngrenzen in %. Dort kannst du verschiedene Sachen einstellen. Vielleicht hilft dir das Gruß Jörg 1 Link to comment Share on other sites More sharing options...
[Ba...] Posted 9 hours ago Author Share Posted 9 hours ago Hi Apfelbach. I use the Zeiss machine for serial measuring and the autorun pallet system for 4 pieces. The problem for us is that it actually closes the previous protocol after each measurement. An extra eye-catching warning is required on the screen for 1-2 very important characteristics that need to be followed among dozens of characteristics. Thank you for the information you gave, but it is not a feature that works for me in my situation. Link to comment Share on other sites More sharing options...
