I am going from GOM to Zeiss. GOM use to show you where the errors were in the program once you dumped the STL in and recalculated it. For some reason I cant get the ZEISS program to show any errors in the inspection except in the report pages and the project guide tab. Does anyone know how to fix this or change the settings so i can see the errors in my program to fix them?
https://qualityforum.zeiss.com/topic/26340-errors-in-program/
  • 2 weeks later...
Hello Alivia,
the errors/hints/recalculations should be displayed in the project guide. The color scheme was changed a bit in the project guide, but it should display the same information as with GOM Inspect.
Which errors are missing and where did you expect them to be shown? It might be possible that in a newer version subsequent errors are filtered out, which did not happen in older versions.
Nanno
https://qualityforum.zeiss.com/topic/26340-errors-in-program/#findComment-149449
