[wo...] Posted April 13 Share Posted April 13 We have a 3 probe rack and up until last week everything was working fine. Then one day last week we were in the middle of a probe change and got this error message. Error with stylus system change: Disk Changed in XXT I do not know what this means but it will not now do an automatic probe change. Link to comment https://qualityforum.zeiss.com/topic/26360-probe-change/ Share on other sites More sharing options...
[Sv...] Posted April 14 Share Posted April 14 Have you activated ID chip recognition? Open the button data management and check the ID chip settings with the button replaced. If you have changed the button, the ID will no longer be correct. Link to comment https://qualityforum.zeiss.com/topic/26360-probe-change/#findComment-149018 Share on other sites More sharing options...
[wo...] Posted April 15 Author Share Posted April 15 Seven, I am not sure what you are talking about, everything was working like a champ since 2023, now it's not. Nothing was changed. Link to comment https://qualityforum.zeiss.com/topic/26360-probe-change/#findComment-149134 Share on other sites More sharing options...
[Br...] Posted April 15 Share Posted April 15 Hello, I am suspecting either your xxt or plate are going bad. i would contact Zeiss Tech support. Link to comment https://qualityforum.zeiss.com/topic/26360-probe-change/#findComment-149160 Share on other sites More sharing options...
[wo...] Posted April 21 Author Share Posted April 21 Bruce, I am not sure that is the problem either, because I do not get the message when we do a manual tool change. Link to comment https://qualityforum.zeiss.com/topic/26360-probe-change/#findComment-149387 Share on other sites More sharing options...
[Br...] Posted May 4 Share Posted May 4 Create a new Machine Tab (refer to the knowledge base section of the portal if you need help creating one) Ref sphere position with MP Create Tool Rack see if you can drop off Master probe and pickup. Link to comment https://qualityforum.zeiss.com/topic/26360-probe-change/#findComment-150060 Share on other sites More sharing options...
