Probe Change
We have a 3 probe rack and up until last week everything was working fine. Then one day last week we were in the middle of a probe change and got this error message.
Error with stylus system change:   Disk Changed in XXT
I do not know what this means but it will not now do an automatic probe change.
Have you activated ID chip recognition? Open the button data management and check the ID chip settings with the button replaced. If you have changed the button, the ID will no longer be correct.
Seven,  I am not sure what you are talking about, everything was working like a champ since 2023, now it's not. Nothing was changed.
Hello,
I am suspecting either your xxt or plate are going bad. i would contact Zeiss Tech support.
Bruce, I am not sure that is the problem either, because I do not get the message when we do a manual tool change.
  • 2 weeks later...
Create a new Machine Tab (refer to the knowledge base section of the portal if you need help creating one)
Ref sphere position with MP
Create Tool Rack
see if you can drop off Master probe and pickup.
