Max/Min Point from a group of points
In Calypso this would be super straightforward. 😞
Either way. I need to measure (6) points and then have the software pull the min/max points, so that those points can be used for subsequent actions.
I see that there is a Minimum and Maximum inside of Inspection - Check Dimensions - Positions - Check Y, but I'm unable to get these to work.
https://qualityforum.zeiss.com/topic/26364-maxmin-point-from-a-group-of-points/
I am not catching your intents here.
I've found you can use MIN and MAX point flag as a measurable point.
This way i am using to get depth of a part marking ( via flatness ). Then just projected distance to that plane.
Also you can use user defined evaluation, where you can use this point as a variable.
I assume your points are having same nominal value in height. So i've made a element group and applied TP.
Now go to Inspection -> Min / Max deviation -> Right click on TP callout and select "Selecct all points of element" - now use All points and Min/Max.
It will create deviation flag, which an be used later as a point
  • Awesome! 1
