[Ri...] Posted 3 hours ago Share Posted 3 hours ago In Calypso this would be super straightforward. 😞 Either way. I need to measure (6) points and then have the software pull the min/max points, so that those points can be used for subsequent actions. I see that there is a Minimum and Maximum inside of Inspection - Check Dimensions - Positions - Check Y, but I'm unable to get these to work. Link to comment Share on other sites More sharing options...
[Ri...] Posted 3 hours ago Author Share Posted 3 hours ago Ahhhh. Progress. You have to create an Element Group from the Points first. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted 2 hours ago Author Share Posted 2 hours ago Any possible way to use said min/max points for subsequent calculations? Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago Please sign in to view this quote. I am not catching your intents here. I've found you can use MIN and MAX point flag as a measurable point. This way i am using to get depth of a part marking ( via flatness ). Then just projected distance to that plane. Also you can use user defined evaluation, where you can use this point as a variable. Link to comment Share on other sites More sharing options...
