[Ji...] Posted April 14 Share Posted April 14 Dear colleagues, in the previous method of evaluating the position tolerance of a hole pattern, modifying the tolerance did not affect the measurement results. However, in the new GD&T evaluation of hole pattern position tolerance, updating the tolerance zone also changes the measurement results. What is the reason for this? What is the difference between the two? Link to comment https://qualityforum.zeiss.com/topic/26366-gdt-position/ Share on other sites More sharing options...
[A...] Posted April 14 Share Posted April 14 Morning! Looking at this, the Pos Tol in the left photo is adjusting the tolerance individually with an allowed Best Fit (Rotational). Calypso looks at the individual tolerances and finds the best position to rotate all features. The main Element that has the most bearing on your rotation is B.1 where the tolerance band is relatively small vs B.4 where you have a much larger tolerance band. Calypso may rotate your elements to try fit B.1 into tolerance even if the element B.4 has to rotate away from its own tolerance center. When you establish a tolerance on the right photo, that tolerance applies to all elements and so B.1 thru B.4 will all be treated equally. Link to comment https://qualityforum.zeiss.com/topic/26366-gdt-position/#findComment-149022 Share on other sites More sharing options...
[Ji...] Posted April 14 Author Share Posted April 14 My understanding is this: In the old hole pattern evaluation method, the best-fit position was calculated based on the nominal values. As a result, the size of the tolerance zone had no influence on the measurement result. The new GD&T feature, however, seems to calculate the best-fit position based on the tolerance zone size of each individual feature. This is just my personal understanding. Is there any official documentation or explanation available for the new GD&T functionality? Link to comment https://qualityforum.zeiss.com/topic/26366-gdt-position/#findComment-149024 Share on other sites More sharing options...
[A...] Posted April 14 Share Posted April 14 I'm sorry, I've only explained Tolerance Best Fit, this is my default and is not everyone's. You have 4 Best Fit options Please sign in to view this quote. With this, I still expect some change to rotation if you are allowing a larger tolerance zone then maybe you do not need additional rotation. Maybe compare the two rotation angle actuals and see how much it changes from one tol-zone to the larger. Link to comment https://qualityforum.zeiss.com/topic/26366-gdt-position/#findComment-149026 Share on other sites More sharing options...
