probe crash and actual pnt issues- Why tho!
I have never run into this issue before, but I can only run some of my curve features using the base alignment. It keeps crashing when I attempt to run a feature using a secondary alignment.
I ran it using the base alignment and got actual data, then I tried to swap it to a secondary alignment afterwards. The result is that it moves all of my actual data around, really screwy.
In the images below, my curve is right at the nominal line; the second image shows it all over with red arrows.
I have not run into this before. Does anyone know what's going on and how to fix it? Calypso version 2021.
image.png.f59acbc144e04c41b3ea8d3b25b5e708.pngimage.thumb.png.af531e706fdb0a5a96ab93076b246400.png
Did you make sure that "Keep Position" isn't checked when you changed to the new alignment?
  • 3 weeks later...
How that part looks like? Curve in one plane or it goes in all three axis?
I would bet that secondary alignment is somewhat rotated and moved.
If you want to have less red points, then increase search distance on a curve. At least you will be able to see what is scanned.
Posted (edited)
I ended up figuring it out!
It was linked to the spatial feature that was in that alignment. The plane that was used for the x origin and spatial alignment was recalled from a 2d curve. I thought this was a bug, so I tried it in the latest version of 2025 with the same outcome. With that said I believe this is a bug, and I have opened a ticket with Zeiss.
How I got it fixed was I had to re-add a plane and recall feature points to recreate the plane. Just recalling the points in the same plane did not work. I don't know how this got messed up or why it reacts like this, but that is how I worked around the issue.
Edited
  • Like! 1
  • Thank you! 1
