[Jo...] Posted April 14 Share Posted April 14 I have never run into this issue before, but I can only run some of my curve features using the base alignment. It keeps crashing when I attempt to run a feature using a secondary alignment. I ran it using the base alignment and got actual data, then I tried to swap it to a secondary alignment afterwards. The result is that it moves all of my actual data around, really screwy. In the images below, my curve is right at the nominal line; the second image shows it all over with red arrows. I have not run into this before. Does anyone know what's going on and how to fix it? Calypso version 2021. Link to comment Share on other sites More sharing options...
[Ze...] Posted April 14 Share Posted April 14 Did you make sure that "Keep Position" isn't checked when you changed to the new alignment? Link to comment Share on other sites More sharing options...
[Jo...] Posted April 14 Author Share Posted April 14 Please sign in to view this username. No, keep position was not checked. Link to comment Share on other sites More sharing options...
[Jo...] Posted yesterday at 07:00 PM Author Share Posted yesterday at 07:00 PM Bump. Still running into this issue 😞 Has anyone seen this before? Link to comment Share on other sites More sharing options...
[Ma...] Posted yesterday at 07:17 PM Share Posted yesterday at 07:17 PM How that part looks like? Curve in one plane or it goes in all three axis? I would bet that secondary alignment is somewhat rotated and moved. If you want to have less red points, then increase search distance on a curve. At least you will be able to see what is scanned. Link to comment Share on other sites More sharing options...
[Jo...] Posted 7 hours ago Author Share Posted 7 hours ago (edited) I ended up figuring it out! It was linked to the spatial feature that was in that alignment. The plane that was used for the x origin and spatial alignment was recalled from a 2d curve. I thought this was a bug, so I tried it in the latest version of 2025 with the same outcome. With that said I believe this is a bug, and I have opened a ticket with Zeiss. How I got it fixed was I had to re-add a plane and recall feature points to recreate the plane. Just recalling the points in the same plane did not work. I don't know how this got messed up or why it reacts like this, but that is how I worked around the issue. Edited 7 hours ago 1 Link to comment Share on other sites More sharing options...
