[To...] Posted April 20 Share Posted April 20 Hello all, I have a composite position call out with 0 tolerance using MMC. I understand that perpendicularity plays into this, but I also need to get orientation and position from 1 slot to the other. I have been trying to do this with bore pattern but have not yet been able to figure this out. I am using calypso 2025. Any help is always appreciated... Thanks Link to comment https://qualityforum.zeiss.com/topic/26407-bore-pattern-with-slots/ Share on other sites More sharing options...
[Ri...] Posted April 20 Share Posted April 20 If you want to do this legally here would be my first suggestion: Measure (4) independent planes on the .050 surface: Create (2) Symmetry Planes (Features - Special Geometries - Symmetry Plane) from the (4) Planes Create (2) Position Characteristics for the upper tier. Turn on SIM Evaluation Create (2) Position Characteristics for the lower tier. Turn on SIM Evaluation Link to comment https://qualityforum.zeiss.com/topic/26407-bore-pattern-with-slots/#findComment-149353 Share on other sites More sharing options...
[To...] Posted April 21 Author Share Posted April 21 Thanks Richard.....So, I wouldn't have to use a best fit pattern for the two slots? Maybe I'm over thinking it, but I thought there was more to it than that. In the end isn't it just perpendicularity to A than? The location and rotation get locked in with AB and the orientation gets locked in when we use just A. Is that correct? Link to comment https://qualityforum.zeiss.com/topic/26407-bore-pattern-with-slots/#findComment-149395 Share on other sites More sharing options...
