[To...] Posted April 21 Share Posted April 21 I am trying to get the position to AB and the position to A. I cannot pull up simultaneous requirement in my position box by using a symmetry plane to the slots. AI keeps telling me to use a slot to do this and that I should be using both slots. How can I do this? I'm new to this version of calypso so the new GDT position is a bit different. Need help. Thanks Link to comment https://qualityforum.zeiss.com/topic/26419-simultaneous-requirment/ Share on other sites More sharing options...
[Du...] Posted April 21 Share Posted April 21 what kind of symmetry plane are you using? i dont think the one under construction would work, believe you would have to use the one under feature and recall feature points from both sides of the slot 2 Link to comment https://qualityforum.zeiss.com/topic/26419-simultaneous-requirment/#findComment-149425 Share on other sites More sharing options...
[To...] Posted April 23 Author Share Posted April 23 I used the one under special geometry. I understand I could also use theoretical circles. Link to comment https://qualityforum.zeiss.com/topic/26419-simultaneous-requirment/#findComment-149547 Share on other sites More sharing options...
[Jo...] Posted April 27 Share Posted April 27 Are you evaluating the slots as individual symmetry planes or one combined symmetry plane? Link to comment https://qualityforum.zeiss.com/topic/26419-simultaneous-requirment/#findComment-149699 Share on other sites More sharing options...
[Ca...] Posted July 1 Share Posted July 1 If anyone comes across this post in the future and is looking for information on how to use simultaneous requirements, more information can be found in this knowledge base article here: https://portal.zeiss.com/knowledge-base?id=3450000 1 Link to comment https://qualityforum.zeiss.com/topic/26419-simultaneous-requirment/#findComment-152399 Share on other sites More sharing options...
