SIMULTANEOUS REQUIRMENT
I am trying to get the position to AB and the position to A. I cannot pull up simultaneous requirement in my position box by using a symmetry plane to the slots. AI keeps telling me to use a slot to do this and that I should be using both slots. How can I do this? I'm new to this version of calypso so the new GDT position is a bit different. Need help. Thanks
what kind of symmetry plane are you using? i dont think the one under construction would work, believe you would have to use the one under feature and recall feature points from both sides of the slot
  • Like! 2
