CAD Presentation
Looking to upgrade to Calypso 2025 (8.0.1203) with our Win11 updates.
I have installed it on an offline laptop to get familiar with it and see how it imports programs.
The drawback is no output for the CAD Presentation commands on the evaluation side. I do remember hearing at the user group meeting this being an issue.
Is there any resolution we know of? I scoured the forum a bit before asking, but nothing too specific about this topic that I was able to find with my limited time.
I did read a lot of discouragement of v.2025 until the lates patches, but hoped since 2026 is coming or is out that this wouldn't still be an issue.
What is a good alternate solution to this method in the new versions?
I apologize if this is a beaten-to-death topic but I seldom use the forums.
https://qualityforum.zeiss.com/topic/26421-cad-presentation/
To be more clear, I'm speaking of the Evaluation command, "CAD Presentation" that lets you use a created/saved CAD image (usually with deviations displayed) as a picture inserted into PiWeb report (StandardProtocol). It worked well in all previous versions I'm familiar with. It "runs" with no runtime errors, but leaves the PiWeb report blank in that area. It lists the feature but fails to display the image as normal. It even lets me create a new feature in this version as normal, but still does not produce an image on PiWeb.
I am using a "Planner" offline key to test it, but I don't think it has any bearings on whether it would be better or worse on a machine license.
Like I said, I had heard that it was "broken" this version, but hoped it was 'fixed' by 2026 (or end of 2025 updates).
If this specific feature does not work, how does one display the plotted images of CAD deviations from Freeform Profiles onto a report in this version??
https://qualityforum.zeiss.com/topic/26421-cad-presentation/#findComment-149503
Exchange row template does need to be on. Make sure filter is either off or you turn on display for the CAD evaluation if it is checked on.
In regard to your glitchy CAD check your nvidia settings (see link below) and make sure drivers are up to date.
https://portal.zeiss.com/knowledge-base?id=528774
  • Like! 1
https://qualityforum.zeiss.com/topic/26421-cad-presentation/#findComment-149621
Hallo zusammen
Mit dem Update auf Version 8.0.12 (zuvor 8.0.08) haben wir ebenfalls das Problem, dass der CAD-Präsentations-Plot in PiWeb nicht mehr angezeigt wird.
Da die beiden oben genannten Links für mich nicht zugänglich sind bzw. möglicherweise gelöscht wurden, wollte ich hier nachfragen, ob es inzwischen eine alternative Lösung gibt. Ich möchte vermeiden, die Anzeigeoption für alle Messprogramme einzeln aktivieren zu müssen. Wir haben tausende Messprogramme, bei denen diese Funktion genutzt wird. Eine manuelle Anpassung möchten wir daher möglichst vermeiden.
Oder wartet ihr alle auf ein neues Service Pack? 🙂
Ich hoffe auf eine positive Rückmeldung.
Gruss
https://qualityforum.zeiss.com/topic/26421-cad-presentation/#findComment-149745
, We're experiencing the same bug, and it's a major letdown.  The error appears to be on the PiWeb side of things.  CAD presentation is one of the most important functions that we use Calypso for, so I hope Zeiss takes this problem seriously and fixes it.
https://qualityforum.zeiss.com/topic/26421-cad-presentation/#findComment-149751
  • 3 weeks later...
