[Ne...] Posted April 21 Share Posted April 21 Looking to upgrade to Calypso 2025 (8.0.1203) with our Win11 updates. I have installed it on an offline laptop to get familiar with it and see how it imports programs. The drawback is no output for the CAD Presentation commands on the evaluation side. I do remember hearing at the user group meeting this being an issue. Is there any resolution we know of? I scoured the forum a bit before asking, but nothing too specific about this topic that I was able to find with my limited time. I did read a lot of discouragement of v.2025 until the lates patches, but hoped since 2026 is coming or is out that this wouldn't still be an issue. What is a good alternate solution to this method in the new versions? I apologize if this is a beaten-to-death topic but I seldom use the forums. Link to comment Share on other sites More sharing options...
[Sv...] Posted April 22 Share Posted April 22 I use Calypso 2025 and have no problems except for the CAD analysis and the fact that no probe is shown in the RDS when changing angles. However, I don't have a planner seat with simulation, so I can't comment on that. We have an SMA, so my management is behind when it comes to updates. Link to comment Share on other sites More sharing options...
[Ne...] Posted April 22 Author Share Posted April 22 To be more clear, I'm speaking of the Evaluation command, "CAD Presentation" that lets you use a created/saved CAD image (usually with deviations displayed) as a picture inserted into PiWeb report (StandardProtocol). It worked well in all previous versions I'm familiar with. It "runs" with no runtime errors, but leaves the PiWeb report blank in that area. It lists the feature but fails to display the image as normal. It even lets me create a new feature in this version as normal, but still does not produce an image on PiWeb. I am using a "Planner" offline key to test it, but I don't think it has any bearings on whether it would be better or worse on a machine license. Like I said, I had heard that it was "broken" this version, but hoped it was 'fixed' by 2026 (or end of 2025 updates). If this specific feature does not work, how does one display the plotted images of CAD deviations from Freeform Profiles onto a report in this version?? Link to comment Share on other sites More sharing options...
[Ri...] Posted April 23 Share Posted April 23 If you are able to create CAD Presentations, have you turned on the "Display plots in report"? Resources Character settings Editor Display plots in report Then you select any characteristic that has a CAD Presentation. 1 Link to comment Share on other sites More sharing options...
[RP...] Posted April 23 Share Posted April 23 Does Exchange row template need to be checked as well? side note, whenever I add cad presentations, my cad model becomes glitchy and rotating/moving the view isn't smooth. Link to comment Share on other sites More sharing options...
[An...] Posted Friday at 04:29 PM Share Posted Friday at 04:29 PM This is currently a known bug and being looked at by development. In the meantime some users have luck by turning on the display option which seems to force trigger the CAD evaluation. Link to comment Share on other sites More sharing options...
[An...] Posted Friday at 04:31 PM Share Posted Friday at 04:31 PM Here is a knowledge base with a little more description on what I am referring to try and fix the issue. https://portal.zeiss.com/knowledge-base?id=3777759 1 Link to comment Share on other sites More sharing options...
[An...] Posted Friday at 04:40 PM Share Posted Friday at 04:40 PM Please sign in to view this quote. Exchange row template does need to be on. Make sure filter is either off or you turn on display for the CAD evaluation if it is checked on. In regard to your glitchy CAD check your nvidia settings (see link below) and make sure drivers are up to date. https://portal.zeiss.com/knowledge-base?id=528774 1 Link to comment Share on other sites More sharing options...
[Ne...] Posted Monday at 04:24 PM Author Share Posted Monday at 04:24 PM Please sign in to view this quote. Thank you, as this is what I was searching for. I will see if this helps in our reports. Thanks again! Link to comment Share on other sites More sharing options...
[Se...] Posted yesterday at 01:52 PM Share Posted yesterday at 01:52 PM Hallo zusammen Mit dem Update auf Version 8.0.12 (zuvor 8.0.08) haben wir ebenfalls das Problem, dass der CAD-Präsentations-Plot in PiWeb nicht mehr angezeigt wird. Da die beiden oben genannten Links für mich nicht zugänglich sind bzw. möglicherweise gelöscht wurden, wollte ich hier nachfragen, ob es inzwischen eine alternative Lösung gibt. Ich möchte vermeiden, die Anzeigeoption für alle Messprogramme einzeln aktivieren zu müssen. Wir haben tausende Messprogramme, bei denen diese Funktion genutzt wird. Eine manuelle Anpassung möchten wir daher möglichst vermeiden. Oder wartet ihr alle auf ein neues Service Pack? 🙂 Ich hoffe auf eine positive Rückmeldung. Gruss Link to comment Share on other sites More sharing options...
[Je...] Posted yesterday at 04:43 PM Share Posted yesterday at 04:43 PM Please sign in to view this username. , We're experiencing the same bug, and it's a major letdown. The error appears to be on the PiWeb side of things. CAD presentation is one of the most important functions that we use Calypso for, so I hope Zeiss takes this problem seriously and fixes it. Link to comment Share on other sites More sharing options...
[Sv...] Posted 12 hours ago Share Posted 12 hours ago Please sign in to view this username. To access the Knowledge Base, go to your profile (outside of the forum) and change your country of origin to the USA. Log out, then log back in, and you will have access. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago Hello together, according to DevOps, this BUG will be fixed with the next upcoming Patch: 8.0.1204, planned release date is May (the) 4th (be with you) 🙂 Best Regards Marcel 2 Link to comment Share on other sites More sharing options...
[Je...] Posted 3 hours ago Share Posted 3 hours ago Please sign in to view this username. , thanks for the update! It means a lot to hear updates directly from the vendor, even if "unofficial." Shows you care. Link to comment Share on other sites More sharing options...
