Keyway centering
When you are filling alignment, then you can use plane as first element, then circle as second element, then just symmetry point from groove to be used as rotation lock.
Using line from symmetry point and center of a circle is unnecessary step.
Then:
if you would use symmetry from two planes ( of width of groove 16 ) then this can be misleading because it's direction won't be to exact center of a circle.
https://qualityforum.zeiss.com/topic/26425-keyway-centering/#findComment-149477
