Position/ISO/New GD&T
I am curious how you want to measure this, but your only option here is either make many lines and do tangential feature ( radius between lines ) or curves.
Then form a plane from each circle's center. But still it should be tangential element - in this case vector of that plane should be outwards from material.
  • Like! 1
https://qualityforum.zeiss.com/topic/26427-positionisonew-gdt/#findComment-149495
I measured Datum A with 16 self centering points (ball Ø3.5), also checked with tangential feature, result was the same, so I chose faster measurement with self centering.
Thanks for help 🙂
Is there any source where I can read about LSQ, tangential etc. how and when to use them?
https://qualityforum.zeiss.com/topic/26427-positionisonew-gdt/#findComment-149507
Calypso_basic_ISO 5459 Section.pdf
good questions about best practices, for me I use inscribe and circonscribe only to have diameters values, for GD&T and datum I use Gauss wich is more stable (even with ISO I should use tangentiel for datum).
LEAST SQUARES DATUM DEFINITION.pdf
the least squares datum definition article explain some behaviors of the differents methodes (even it give me a headache, it's realy interesting)
  • Like! 2
https://qualityforum.zeiss.com/topic/26427-positionisonew-gdt/#findComment-149525
