[Ar...] Posted 5 hours ago Share Posted 5 hours ago Hello, I have mesh/CAD comparison of a certain part. In this deviation analysis I can clearly see the deviating areas but what I am trying to do is to mark deviation where we have a sharp angle deviation from the surface. Does anyone know if this is possible? You can see in the image where we have this deviation but I don't know if this is sharp enough or not. Any tool that would give me that measure? Link to comment Share on other sites More sharing options...
[Na...] Posted 2 hours ago Share Posted 2 hours ago Hello Arda, are you interested in the deviation of the normals of the actual surface to the nominal surface? This function might help in this case: Create Draft Angle Map If you are interested in the defects, you can create a surface defect map and then create surface defects: 1. Create Surface Defect Map 2. Create Surface Defect Element Link to comment Share on other sites More sharing options...
