[Ja...] Posted April 23 Share Posted April 23 I have tried several different .dxf files, and I cannot get any of them to open in Calypso. I followed the steps of importing the cad file, but I get an error message every time (see below). Any help would be great. Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/ Share on other sites More sharing options...
[ni...] Posted April 23 Share Posted April 23 try to convert it in .sat with an other application before open it with calypso. Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-149543 Share on other sites More sharing options...
[Ja...] Posted May 7 Author Share Posted May 7 I can load dxf files on the other CMM (same software version, 2010 model), but ont he new one, i keep getting this error. I do not have any other software I can utilize at the moment to convert it to step Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-150318 Share on other sites More sharing options...
[Ca...] Posted May 7 Share Posted May 7 Are both computers (the one that it will pull in on and the one that it wont) running CALYPSO 8.0.08? 1 Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-150322 Share on other sites More sharing options...
[Ch...] Posted May 7 Share Posted May 7 I know for a fact that the attached Curve B.dxf model file works on my PC with CALYPSOP 8.0.12. You can try it on your PC to see if the CALYPSO version is at fault or if it could be something about your particular .dxf files? Curve B.dxf Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-150330 Share on other sites More sharing options...
[ni...] Posted May 18 Share Posted May 18 so, load dxf on other MMt, record the program, and load the .sab file in an other program in your new CMM Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-150720 Share on other sites More sharing options...
[Ja...] Posted May 28 Author Share Posted May 28 I tried and got the same error on the newer machine, but loaded fine on the old machine. Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-151280 Share on other sites More sharing options...
[Ja...] Posted May 28 Author Share Posted May 28 Please sign in to view this quote. Thats what I am doing now, it works, but not preferred. It should load on the newer machine as well. Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-151282 Share on other sites More sharing options...
[Ch...] Posted May 29 Share Posted May 29 I see, in that case I would suspect the CALYPSO version may be at fault. Looks like you are running a slightly older version 8.0.08 where as I was running/testing in 8.0.12. Maybe you can try updating your Service Pack to 8.0.12 or 8.0.1204 to ensure compatibility. How to Download & Install CALYPSO Service Packs Link to comment https://qualityforum.zeiss.com/topic/26435-issue-loading-dxf-file/#findComment-151382 Share on other sites More sharing options...
