Measurement Plan Could Not Be Loaded
We are trying to load a proven measurement plan, and we get the message "Measurement Plan Could Not Be Loaded." This is the first time that I have gotten this message, and I am confused by it. I have a couple other programs for this part that load just fine.
Does anyone know how to fix this, other than rewriting the program? It's a rather complicated program to re-write, but if that's what we have to do, we will.
All help is appreciated.
https://qualityforum.zeiss.com/topic/26437-measurement-plan-could-not-be-loaded/
Check the contents of the offending folder compared to a folder where the program does load.
Compare file names and see if some files are missing.
Do you not have back ups?
As a note, all of my files reside on a server, these are copied to the local drive to run. This way you should never lose the original program integrity.
Richard,
Thanks for the response. I am at a loss as this issue has not come up before.
I think I have attached pictures my files. One is REV 10 version of the program, which loads fine, the other is the REV 11 version that won't load.
I did notice that on the REV 11 file, there is a folder titled "TEMP" and that is the one that won't load. In the TEMP folder is a sub-folder titled "GEOACTUALS".
I'm not sure if that is the issue or not.
We store our programs on our network that is backed up every day. I might get with our IT department and see if they can load the program from a couple days ago.
Loads Properly.pdf Measurement Plan Could Not Be Loaded.pdf
