[No...] Posted 15 hours ago Share Posted 15 hours ago Ist es möglich, eine Messreihe, die bereits über Ref.-Punkte oder Flächen in eine andere transformiert wurde, wieder zu "enttransformieren"? Link to comment Share on other sites More sharing options...
[Ma...] Posted 14 hours ago Share Posted 14 hours ago Not found yet. I also found, that i either don't understand how it works or it's not doing what it should but: I have 3 scans. 2nd is transformed to 1st and i don't see additional data on 1st while transforming 3rd into 1st. Link to comment Share on other sites More sharing options...
[Na...] Posted 13 hours ago Share Posted 13 hours ago Man kann die eine Messreihe bearbeiten -> Messreihenabhängigkeit auf 'Abhängig' -> Messreihenabhängigkeit auf 'Unabhängig'. Dann sind sie wieder unabhängig. Please sign in to view this username. Please sign in to view this quote. I don't fully understand: The data is not displayed or the transformation does not work? Maybe it's simple and the measurements (M1, M2, ...) are set to visible, but the Measuring series 3 is not? Link to comment Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Share Posted 4 hours ago Please sign in to view this username. What i saw was only 1st and 3rd. I thought i would see 1st and 2nd combined and i wanted to transform 3rd into 1st. I think i had a problem with ref. points which should be common among 2nd and 3rd, but not in 3rd and 1st. 2nd and 1st had other common ref. points. Or i just got lost on that complex part Link to comment Share on other sites More sharing options...
