Messreihe "enttransformieren"
Ist es möglich, eine Messreihe, die bereits ĂŒber Ref.-Punkte oder FlĂ€chen in eine andere transformiert wurde, wieder zu "enttransformieren"?
Not found yet.
I also found, that i either don't understand how it works or it's not doing what it should but: I have 3 scans. 2nd is transformed to 1st and i don't see additional data on 1st while transforming 3rd into 1st.
Man kann die eine Messreihe bearbeiten -> MessreihenabhÀngigkeit auf 'AbhÀngig' -> MessreihenabhÀngigkeit auf 'UnabhÀngig'.
Dann sind sie wieder unabhÀngig.
I don't fully understand: The data is not displayed or the transformation does not work? Maybe it's simple and the measurements (M1, M2, ...) are set to visible, but the Measuring series 3 is not?
What i saw was only 1st and 3rd. I thought i would see 1st and 2nd combined and i wanted to transform 3rd into 1st.
I think i had a problem with ref. points which should be common among 2nd and 3rd, but not in 3rd and 1st.
2nd and 1st had other common ref. points.
Or i just got lost on that complex part
You can change the measurement series dependency at any time, which would "undo" the transformation.
If 1, 2 and 3 are sharing the same reference points, 3 into one should work. If 1 and 2 share reference points, and 2 and one: Transform 3 into 2 and 2 into 1. Hope that makes sense 😄
Oh, doch so einfachÂ đŸ€­Â Werde ich heute gleich mal ausprobieren.
Posted (edited)
Anmerkung: Man sollte zwischen der Umschaltung von unabhÀngig auf abhÀngig keine Neuberechnung machen. Das bescherte mir einen reproduzierbaren Software-Crash.
  • 2 weeks later...
  • 2 weeks later...
I could not reproduce it with a sample project in 2026 SP1. Could you please contact your local support with logs and maybe the project?
Das Projekt, wo das passierte, existiert so nicht mehr (ich erzeuge es meistens nur temporĂ€r fĂŒrs Scanning). Auch keine Logs u.Ă€. Ich könnte auch nicht sicher sagen, ob ich das SP1 schon installiert hatte oder nicht.
Den Fall, daß ich die Transformation aufheben musste, hatte ich vorher auch noch nie und wird so schnell auch nicht mehr auftreten. Da war mir ein Fehler passiert und ich wollte nicht nochmal von vorn anfangen.
