[Jo...] Posted April 24 Share Posted April 24 I export our data into a csv file, and I would like to change the order of the output. I would like to order it the same as the characteristic number, but we always group by characteristic (there's usually more than one measurement so that's why we group by characteristic). So in this example, the 0.1513 diameter would be at the top of the csv file and then 0.167 followed by 0.3063 and finally the luer taper would be last. I can't find any information about this order number or how to change it. Link to comment https://qualityforum.zeiss.com/topic/26447-how-do-i-change-this-dang-order-number-in-piweb/ Share on other sites More sharing options...
[Ri...] Posted April 24 Share Posted April 24 If you export via a measurement table inside of a PiWeb Report that is sorted via Characteristic Number then it will be in this order. Otherwise you would need to manipulate the data yourself if you are exporting via the PiWeb Reporting Plus database (but having said that, just move the order column to the first column, then sort that way; or use Pivot tables). Link to comment https://qualityforum.zeiss.com/topic/26447-how-do-i-change-this-dang-order-number-in-piweb/#findComment-149605 Share on other sites More sharing options...
[An...] Posted May 5 Share Posted May 5 Here is the link on how to export using measurement tables as Richard mentioned above. The export option through PiWeb reporting plus is a bit limited at customization. https://portal.zeiss.com/knowledge-base?id=513250 Link to comment https://qualityforum.zeiss.com/topic/26447-how-do-i-change-this-dang-order-number-in-piweb/#findComment-150124 Share on other sites More sharing options...
