Clocking to the outside of a hole on round part
I have a round part with a plane on top, think of a round disc. There is a slot on the part at -15 degrees that is a clocking feature. There is a basic angle from the center of the slot that says 75 degrees. Essentially this is sitting at -90 degrees. Then there is a hole that is called out at 35 degrees further, but that angle is to the far side of the hole. How do I draw a line from the center of the major of to far outside edge of the hole.
Essentially the slot is at 4 o'clock. The basic 75 goes from 4 o'clock to six o'clock. The hole is at roughly 7:30 but the line goes to the left side of the hole instead of the center.
A sketch would be helpfull here.
I would measure symmetry point at that slot. Now you can recall center circle and this point to make a 3d line used for clocking. Don't forget in special use rotation.
Another thing is how to perform measurement in CNC mode, when your part is not always at same spot and rotation.
I highly doubt that you will have any dimension to edge of a hole. But as i stated on first line - a sketch would be helpfull.
 If the correct nominal angle does not appear when you select the Tangent1 and the CenterLine 3dLine, this could mean the nominal values of the features used to build Tangent1 and CenterLine 3dLine are not correct or are not at the same Z height or not perpendicular to the Z axis.  If nominal features are correct but they are at different Z's or not perpendicular to Z, you can project the 2 lines to the top plane and do an Angle between Features of the 2 projections.
Edited
  • Thank you! 1
