combine reports from 2 different programs
Hey Alaa,
have a look in the start menu. There should ne somthing called Mastersplan or something simmilar. With that you can combine 2 programms. I think they need to have the same origin and alignment.
I only used it once like 3 years ago so i cant help with any details.
hope it helps
Your advice is for Calypso - here is Inspection section - no such thing here.
You can have another actual data in clipboard or in stage, but i am not sure if you can have there elements. So it would be only for the same CAD model.
Then i don't know why bother with secondary program.
I've done one program for all our production stages, then made separate report pages for each stage and marked them with TAG so i can filter what will be on report PDF.
  • Thank you! 1
