GDT Profile, FF vs Feature & Best Fit
Hello smart people!
I'm trying to get up to speed on the new GD&T engine and profile characteristics. I have a couple of questions...
1) I get different results if I use the feature itself (a cone in this case) as opposed to using a freeform surface created from the cone in the GDT profile characteristic. Which is the correct way to inspect profile?
2) It looks like you can't use an alignment in the GDT profile characteristic. For example, I used to use a best fit alignment created from a bore pattern in my profile characteristic to use   a hole pattern as a tertiary datum. How would I do that in the GDT profile characteristic?
Thanks as always for your help!
BTW... I'm using Calypso 2024
Edited
https://qualityforum.zeiss.com/topic/26502-gdt-profile-ff-vs-feature-best-fit/
Thank you, Richard, You're always very helpful. I really appreciate it!
Something about checking "Loose" makes me feel uneasy in measurement software. lol
I'm measuring some fairly tight profiles and am trying to coordinate with outside vendors on results, so I'm really trying to make sure I'm doing things as accurately as possible.
Does Calypso 2025 have the same behavior in the GDT profile? I want upgrade but am holding off as there seems to be some bugs still being worked out in 2025.
  • Awesome! 1
Yeah, the name Loose probably needs to change - lol.
Two big changes from 2023/2024 to 2025 are the fact that we can do FFS inside of the new Profile, and now you can create an Alignment from the DRF that is created inside a GD&T characteristic.
The new GDT Profile in 2025+ will have virtually all of the tools that you need, you can even do unequally disposed profile or UZ profiles (the software automatically sets it up based on which standard you are using).
