Circle coordinates nominals in CAD not exactly matching with 2D drawing nominals
Version of Calypso?
File format of CAD?
I have never face this - only if model was not correct, but models from SolidWorks ( in SAT and IGES ) are correct once i extract key features for base alignment and setup.
Other extracted features are then ok.
Although it is probably the least likely cause, may I ask what kind of parts we talk about? If it's plastic or otherwise molded parts, they usually have draft angles and I cannot count the number of prints I've seen where even the designer wasn't able to hit the correct one of two edges (start or end of draft) in 2D dimensioning.
