[Ra...] Posted May 1 Share Posted May 1 Hi - I was questioned about these plots about why the min/max in the corner chart doesn't add up to the overall Flatness, and I wasn't sure. Should it? I never really paid attention until now. These were (6) diameter planes compiled into (1) plane. Note: I have a few of these scans and none come close regarding the expected ABS MIN+MAX= flatness. Thanks! 1 Link to comment https://qualityforum.zeiss.com/topic/26510-min-max-flatness-plot/ Share on other sites More sharing options...
[Ke...] Posted May 1 Share Posted May 1 I would presume that the corner box values are simply "where are the min/max points located relative to the alignment", which is seperate from the Measured value that is meing evaluated to the Minimum Feature plane. 1 Link to comment https://qualityforum.zeiss.com/topic/26510-min-max-flatness-plot/#findComment-149966 Share on other sites More sharing options...
[Ri...] Posted May 1 Share Posted May 1 (edited) The Max is 0.0038, and the Min is 0.0000 = 0.0038 Flatness. It's location is just where it is respective to its alignment - flatness is irrelevant to location/orientation. Edited May 1 1 Link to comment https://qualityforum.zeiss.com/topic/26510-min-max-flatness-plot/#findComment-149970 Share on other sites More sharing options...
[Je...] Posted May 1 Share Posted May 1 What Keith and Richard said. The likely difference between the reported flatness and the Min./Max. in the grid you referenced in PiWeb relates to the alignment that the Min./Max. are generated from. Flatness uses minimum feature as the standard evaluation method, which isolates the unrelated mating envelope (i.e. doesn't relate to a datum reference frame). This is a key advantage of digital systems such as a CMM. The feature can be isolated to itself to evaluate form characteristics such as flatness. Link to comment https://qualityforum.zeiss.com/topic/26510-min-max-flatness-plot/#findComment-149972 Share on other sites More sharing options...
